Farmall M not charging
Ann JB Walt
08-13-2002 12:00:37
We have a Farmall M (1952) and recently converted it from 6V to 12V, but it won't charge - any ideas? It wasn't holding a charge at the 6V and we thought by upgrading it, we'd find a change.
Doug in OR
08-13-2002 12:35:26
 Re: Farmall M not charging in reply to Ann JB Walt, 08-13-2002 12:00:37
Tell me more. Did you convert it to an alternator or a generator? Using a good voltmeter, what kind of voltage do you have coming from the alternator/generator? Be as precise as possible. You should be seeing something around 13.8 volts. 13.0 volts would not be good enough. Take some readings and fill me in. I can go from there.
Ann JB Walt
08-13-2002 12:21:02
Okay - an update - the VOLT METER shows that the Battery is charging as the tractor runs - but the AMP METER on the tractor reads a high negative as the tractor runs - any ideas what would cause that?
Ann JB Walt
08-13-2002 12:18:19
Bob M
08-13-2002 13:32:19
 Re: Re: Farmall M not charging in reply to Ann JB Walt, 08-13-2002 12:18:19
Ann - If the voltmeter says it's charging while the ammeter shows a large discharge, the ammeter's reading "backward" on account of a polarity change when the 12 volt conversion was done. (I presume your M is now negative ground....) You can do like Red says and swap the wires at the ammeter, or simply leave it as is and just recognize the ammeter readings are reversed.
The Red
08-13-2002 12:27:52
Are you now 12 volt negative ground vs. 6 volt positive ground? If so, swap the wires on the ampmeter.
Ann JB Walt
08-13-2002 16:27:40
 Re: Re: Re: Farmall M not charging in reply to The Red, 08-13-2002 12:27:52
Thanks all - JB is trying those suggestions now - he is hooking up the lights and agrees that it is probably reading "backwards."
