What Size Rims Does My 230 Farmall Have? I aint payinn $300 plus!!!
drizler
08-09-2002 19:19:29
I have 12/4 11.36 tires on my Farmall 230 1959. The local dealer says I need a special rim made up for a whopping $270 and freight to replace one. That just aint gonna happen in my lifetime. So just what is the rim size for this tire? As best I can measure it its 36 across and about 10" wide as best I can measure with everything in the way. Any grand ideas for less than Mercedes benz prices or do I have to get out the welder, its nasty rusted and falling apart by the tire valve.
Jim in Michigan
08-10-2002 16:03:51
 Re: What Size Rims Does My 230 Farmall Have? I aint payinn $300 plus!!! in reply to drizler, 08-09-2002 19:19:29
I have a set of rims for a C farmall I am pretty sure they are the same,, e mail me if interested....Jim
foocenhaber@yahoo.com
The Red
08-10-2002 03:43:55
Punch below. Miller does show an 11x36 rim for substantially less money then you were quoted.
Drizler
08-10-2002 10:23:05
 Re: Re: What Size Rims Does My 230 Farmall Have? I aint payinn $300 plus!!! in reply to The Red, 08-10-2002 03:43:55
Those tires Miller has are plain rims with no lugs in 36 /11. My luga are bolted on somehow it seems. Have any of you guys ever converted to lugs like this? Locating them would be a snap. Any ideas? $200 or less with shipping seems not so terrible. The first thing it will get is 35-40% Sams Club antifreeze mix. Its never frozen in my Ferguson and up in Northern NY thats saying something. At -$30/ tire its still a bargain.
The Red
08-10-2002 11:19:04
 Re: Re: Re: What Size Rims Does My 230 Farmall Have? I aint payinn $300 plus!!! in reply to Drizler, 08-10-2002 10:23:05
I would give Miller Tire a call next week. Phone number is at the bottom of their webpage. Describe to them your model and what your rims are like. They might have them. I don't think they post their whole inventory on their website. I bought tires and rims from them for a Farmall H 3 years ago. Rim even had the welded on blocks to fit the slot on the hubs!
If you are going to fill the tires, you might want to get painted and primed rims from Miller if available in your size.
drizler
08-10-2002 19:27:23
 Re: Re: Re: Re: What Size Rims Does My 230 Farmall Have? I aint payinn $300 plus!!! in reply to The Red, 08-10-2002 11:19:04
I will have to call them. Unfortunately this beasty needs the weight to counter that loader which is about all I use it for. Thanx for the help guys!
Don LC
08-09-2002 20:55:20
Cut out the section that is bad ...Make your self up a patch and weld it in and finish it,ready to paint....Then mesure off of the good rim,for the valve hole...go to a differn't area on the repaired rim and drill a new hole for the valve.....you have just made $300 to buy other parts.....
I agree
08-10-2002 08:36:09
 Re: Re: What Size Rims Does My 230 Farmall Have? I aint payinn $300 plus!!! in reply to Don LC, 08-09-2002 20:55:20
.. your dealing with less than 20 lbs pressure.
Cliff Neubauer
08-09-2002 20:11:09
If it is solid everwhere but around the valve stem it can probably be repaired, I replaced part of a 38" rim with a section of rim I could out of an old dual rim. Anymore 36" tires and rims are few and far between so that price might not be bad for a new one. You might be able to switch both back tires to another size cheaper than a new 36" rim.
