'48' C ENGINE
I RIGHT I
08-02-2002 19:06:19
I have a 1948 'C' Farmall that I just bought to restore. The engine was stuck very tight from sitting outside for 10+ years and now that I have it apart, It looks like I need a new sleeve and a connecting rod.The piston looks good,so is it necessary to replace it along with the sleeve?
Jim in michigan
08-05-2002 11:10:18
 Re: '48' C ENGINE in reply to I RIGHT I, 08-02-2002 19:06:19
I have a C engine that I am tearing apart for parts.. I have connecting rods to sell,also other C parts,,Jim
KillerRed
08-03-2002 05:52:52
Since you have it apart, do yourself a favor and install a rebuild set. You will be happier than doing the job half fast and the tractor will last another 50+ years.
Just my 2 cents.
Dave_Id
08-02-2002 19:14:25
I'm not sure you can buy just 1 sleeve, but if you can, and everything is in specs as far as ring end clearance, then i see no reason to replace the piston.
