Re: trouble w/hydalics on super c/HELP!!!
gene b
07-24-2002 23:59:43
you can remove the slotted screw on the pump and put some oil in that hole turn engine over a little and fill again and that will prime it this works for me was the shaft worn bad at the seal journal sometimes you need a speedy sleeve on the shaft
