Re: is it possible to get a 450 under 6000 lbs.
JCM
07-24-2002 15:48:54
Get rid of the fluid in the tires and go to a standard drawbar because that fast hitch is heavier than you think. I have a 400 i finished restoring last year and removed my fh and put a std. draw bar on for pulling and to shed weight.I wanted to pull in the 7500lb class at pull last fall and had now idea what the tractor was going to weigh so I got on the scales with a pair of frame weights (125lb ea) and a set of rear wheel weights (145lb ea) and weighed 6300lb.I myself weigh 250lb and of course the next scale I weigh on will give something different but thats what it was for that night.
