1950 W-4
Larry
07-21-2002 20:22:17
Ineed some advice on my W-4 McCormick. It has a mag and I have never missed with one before. The tractor will run ok but when you get it warmed up and under a load it miss's . I have replaced the plugs and put a condensor in the mag. I have also had a carb kit installed. Still not running real smooth. Looking for some good ideas. Thanks
Larry
07-22-2002 20:06:22
 Re: 1950 W-4 in reply to Larry, 07-21-2002 20:22:17
Thanks guys for the ideas and I'm going to give them a try!
BIG JOHN in KS
07-22-2002 18:43:28
Larry, as Zonie said wires could be your problem. Be sure you get copper wires. Just put a set that I got from IH dealer (about $10.) on a "B" and it really smoothed it out. Automotive wires are not made for use with a Mag.
Zonie
07-21-2002 22:11:28
It sounds to me as thou you might need plug wires, and/or to adjust the valves. you could also need points in the magneto.
I hope this helps.
