Farmall M-Need carburetor setting
Gil
07-14-2002 18:08:27
I recently obtained a 1949 Farmall M. It is running rich. Does anyone have a setting to lean out the carburetor?
Doug in OR
07-14-2002 19:13:24
 Re: Farmall M-Need carburetor setting in reply to Gil, 07-14-2002 18:08:27
I've seen elsewhere in here.. to open the throttle.. then screw the power screw (the one on the bottom) inward until the engine just begins to run rough. Then back it out 1/2 turn.
Travis
07-14-2002 18:36:37
If you know which is the main fuel adjustment screw, usually on the bottom of the carb, turn it all the in to seat it (gently) and back it out 2 1/2 to 3 turns.
