I Love my M but..................
On2Wheels
07-05-2002 04:48:09
I was replacing the seal for the main drive shaft that comes off the transmission case. Got the seal housing off ok, but when I went to remove the piece from the main shaft on the transmission that connects to the engine side shaft (the one that goes into the clutch)when pulling it off the shaft it was long enough to hit the engine side shaft. Well to make a long story short I ended up removing the entire clucth assembly so as to make enough room. The engineers dropped the ball on this one. That area could have been 1 inch longer to accomadate the removal of the shaft from the transmission.
If there is a trick to this I certainly could not figure it out. Now an H dosen't have this problem as it is long enough in this area.
Bob in SE Nebraska
07-05-2002 07:03:04
 Re: I Love my M but.................. in reply to On2Wheels, 07-05-2002 04:48:09
I had the same problem with a Super M. I was able to support the tractor front end and unbolt the tractor where one would normally split the tractor. I didn't take the bolts completely out but it gave me enough room to take apart things so I could replace that seal.
Bob
