Finding BN parts-
Will
07-01-2002 09:36:30
First of all, thanks to everyone who had a suggestion on the gas tank.
Now for a bigger quandry.
A few months ago I bought B for parts. In doing some research on S/N, I discovered that originally it was a BN, but had been altered.
Anyone know how to put it back like it used to be?
I got the engine loose, and ended up not taking anything off it-at least nothing that can't easily be replaced.
Can you find the narrow axles, or can the long ones be cut down?
Are there any other differences?
gene b
07-01-2002 20:55:52
 Re: Finding BN parts- in reply to Will, 07-01-2002 09:36:30
measure the axle housings if they measure 18in they are BN if they measure 22in they are Bs might have just changed the seat bracket let me know as i have some parts and also have two BNs and several Bs people get these confused sometimes the right side axle will work off an A but the housing is different there is a difference in the axles as the brake drims are different places from the right to the left does you seat have a gap between the mount ar is it right by the fender glad to help dont be afraid to ask me anything
Haas
07-01-2002 13:44:36
The B only came with the tricycle style front axle. I gather yours has a wide front. You can't cut the wide front axle down and make a tricycle out of it. Your best bet is to find a salvage yard and locate a B front bolster and pedestal. If someone put an A front on your tractor, then the steering gear and steering shafts will be wrong too, so you'll have to get all that from the salvage yard too. Note that A Farmall C steering gear is similar to the B, but will not work on the B. The steering shaft comes out on the opposite side.
William Ransom
07-01-2002 14:18:45
 Re: Re: Finding BN parts- in reply to Haas, 07-01-2002 13:44:36
I think he meant rear axles. A BN has shorter rear axles than a B.
Fred
07-01-2002 18:56:17
 Re: Re: Re: Finding BN parts- in reply to William Ransom, 07-01-2002 14:18:45
The left axle is much longer than the A's, the right side might be the same.
big fred
07-01-2002 10:06:13
I think you can replace the axles with A axles, even though there are some minor differences. I don't recall right now what the differences are, I could probably tell you if I was at home. The platform floor is different, but there again you could use the A parts.
