I-544 Power Steering question, bad vibrations.
Grampsold544
06-28-2002 05:12:38
I finially got my I-544 to run. I drove it around and when I would turn the steering wheel would sometimes vibrate and make a gear grinding sound. I have hyrdostat power steering. Is there some adjustment I need to make to correct this problem.
K.B.
06-28-2002 13:12:00
 Re: I-544 Power Steering question, bad vibrations. in reply to Grampsold544, 06-28-2002 05:12:38
Not quite sure if what you are caling hydrostat power steering is the same power steering system found in most of these tractors 544-656-666-686, or somthing different, but that noise could be caused by air in the system, or mabey a plugged hydraulic filter. Change the filter, and work the remote hydraulic valve levers back and forth to get air out of the hyd. system.
Grampsold544
07-01-2002 08:56:45
 Re: Re: I-544 Power Steering question, bad vibrations. in reply to K.B., 06-28-2002 13:12:00
How do I work the air out with the hydralics if I do not have any thing attached? It the plugs are all sealed how does the air escape?
