1951 H
Troy Pestrak
06-17-2002 12:11:02
2 prob.
1- hard starting
2- easy flooding
new plugs, points, wires,dist, rotor. pull starts in 5 ft. seems to run a little rich, but i dont have carb info. no smoke. any ideas???
The Red
06-17-2002 12:36:52
 Re: 1951 H in reply to Troy Pestrak, 06-17-2002 12:11:02
Troy after the H is warmed up, set the throttle at full speed and lean the high speed mixture screw until the RPM starts to drop off. Then open the screw back up 1/2 turn. Mixture wise that should get you in the ballpark.
Retard your timing about 10 degrees and see if that helps the starting situation. Might be too far advanced.
