350 Farmall Runs, but misses
need help!
Gill
08-13-1999 05:17:10
Can't figure this one out. Tractor starts and runs, but misses every 1 or 2 seconds, miss increases with engine speed. Have changed coil, distributor, points, condensor, plug wires. Tractor ran great till 2 weeks ago when helper was mowing with it. Compression checks 140 psi all four cylinders. If I uplug one or two cylinders, tractor runs smoother than with four! Overhauled two years ago. Any suggestions on what to try next would be greatly appreciated!
The Red. Smells like
08-13-1999 07:07:16
 Re: 350 Farmall Runs, but misses - need help! in reply to Gill, 08-13-1999 05:17:10
Gill, you might have a broken spring in your distributor. Since it gets worse as you speed up, the timing appears not to be advancing correctly. You will have to remove the breaker plate and you should beable to see if that is the culprit.
Phil Auten
08-13-1999 05:30:17
Gill,
Have you tried adjusting the low and high speed adjustments on the carb? Look at the spark plugs to see if they can tell you anything. With unleaded gas they should look gray to charcoal, not black or oily. Check for water in the fuel. As a last resort, check the valve lash and the timing with a timing light. If the timing isn't steady, your distributor shaft bushings may be worn. Check them for side play, and replace the rotor (you didn't mention changing that) while you're at it.
One more thing, check the battery. A weak battery can drag down the electrical system and cause a weak spark.
Let us know what you find,
Phil
Gill
08-13-1999 10:24:21
 Re: Re: 350 Farmall Runs, but misses - need help! in reply to Phil Auten, 08-13-1999 05:30:17
Spark plugs are all black. What does this mean? I don't have access to a timing light and have never used one.
The Red
08-13-1999 10:33:26
 Re: Re: Re: 350 Farmall Runs, but misses - need help! in reply to Gill, 08-13-1999 10:24:21
Gill your mixture is way too rich if they are black. I would lean the high speed mixture screw in until it starts to die then open it back up about a 1/4 turn and see if that helps.
Gill
08-13-1999 10:38:51
 Re: Re: Re: Re: 350 Farmall Runs, but misses - need help! in reply to The Red, 08-13-1999 10:33:26
The high speed mix screw is the longer one on the carburetor by the float, and the idle screw is the shorter one higher up that comes out at an angle, correct?
The Red
08-13-1999 10:50:05
 Re: Re: Re: Re: Re: 350 Farmall Runs, but misses - need help! in reply to Gill, 08-13-1999 10:38:51
Yes sir!
Bob M
08-13-1999 06:53:39
A couple more inexpensive suggestions to add to Phil's: Put in a new set of plugs - suggest D-21 or equivalent - and see what happens. Also replace the distributor cap - a cracked or carbon-tracked cap can cause misfiring.
TomH
08-13-1999 16:54:51
 Re: Re: Re: 350 Farmall Runs, but misses - need help! in reply to Bob M, 08-13-1999 06:53:39
This sounds more like ignition than fuel. Miss is often a sign of bad cap and/or rotor.
Replace the rotor and double check the gap on the points, they move around a lot when you tighten them down.
A cheapo timing light shouldn't be more that about $30, it's worth it.
