H starter
Phlogiston
05-25-2002 10:17:57
I need to replace the bendix gear on a starter for an H. Is this hard? What steps are involved.
Thanks guys.
BIG JOHN
05-25-2002 16:52:57
 Re: H starter in reply to Phlogiston, 05-25-2002 10:17:57
You will find that the Bendix's are a bit pricey.
Best price I found was at Steel Wheel Ranch.
I found a used complete starter cheaper than a new Bendix.
Farmall Ed
05-25-2002 13:41:04
Its been about 3 years since I replaced one,but as I recall it was fairly easy.After the starter is off the tractor remove the two long bolts holding the starter together,there may be some screws holding a plate inside you will have to remove.Best I remember mine (the bendix) was fastened with a couple of bolts.BE careful with the brushes on reassembly.Hope this helps,someone in this area more recent could probaly help you more.Ed
