IH 484 Clutch
Gerald
08-11-1999 21:33:35
A friend of mine has an early 80's 484 utility tractor, for the 1st 15 years or so no problem. Twice in the last 4 yrs. the clutch has gone out. Now it is slipping again. The 1st repair was by an IH dealer, the 2nd repair was at a Ford dealer (don't ask why). Anyway the Ford dealer claimed the tractor was built in England & only inferior aftermarket parts were available & that he could expect it to be a re-occuring problem. Does anyone know if this is correct?
RickB.
08-12-1999 15:01:07
 Re: IH 484 Clutch in reply to Gerald, 08-11-1999 21:33:35
Good quality clutch discs & pressure plates are available from OEM & aftermarket sources for this tractor. The next time it is split, be CERTAIN the flywheel step dimension is correct. If the flywheel was cut or turned without turning down the step where the pressure plate mounts, the lockup pressure on the disc will be insufficient to ensure good disc life.
BDM
08-12-1999 17:57:38
 Re: Re: IH 484 Clutch in reply to RickB., 08-12-1999 15:01:07
How would you know the proper measurements? Are there specs to measure between the step and clutch face on the flywheel? I would like to know for my own info.Thx.
Brian
RickB.
08-13-1999 14:36:10
 Re: Re: Re: IH 484 Clutch in reply to BDM, 08-12-1999 17:57:38
This info is in the original IH service manual, MAY be included in the IT service manual, and is listed in the IH clutch section of the Hy-Capacity parts catalog. Hy-Capacity is an aftermarket parts source located in Humbolt, Iowa. I believe they only wholesale to dealers, but they have good products at excellent prices & stand behind their stuff. Some ag equip. dealers carry their line. Any aftermarket clutch source worth a darn should be able to provide this info, it's in their own best interest for you to do it right.
BDM
08-13-1999 17:37:59
 Re: Re: Re: Re: IH 484 Clutch in reply to RickB., 08-13-1999 14:36:10
Thx Rick I will chk this out.
Brian
