Re: unfamiliar territory :diesels
Red Baron
05-10-2002 06:06:45
You probably twisted off the pump drive shaft. Take off the small inspection cover on the side of the injection pump and see if the head is turning when you crank on the engine. If ti is not the pump will have to be removed and sent ot a pump repair shop.
jfee
05-10-2002 15:46:45
 Re: Re: unfamiliar territory :diesels in reply to Red Baron, 05-10-2002 06:06:45
red baron. i think your right, i pulled off timing cover on roosa master pump, cranked over engine &ddid not see any movement at pump.i have aspare pump but better get some to change.
