SC with a dead short
Farmer Bob
05-05-2002 15:16:11
Ran the SC today and everything worked fine. Shut her down and tried restarting it about 5 mins later. As soon as I pull out the on/off switch the ampmeter pegs (Slams)to the neg side. I've tried to narrow it down with test equipment but can't seem to locate the problem. Any help out there? Almost hairless!
howard
05-05-2002 15:55:01
 Re: SC with a dead short in reply to Farmer Bob, 05-05-2002 15:16:11
I'd check and see if the points in the voltage reg aren't sticking. sometimes a little tap on the cover will set things straight.
Farmer Bob
05-05-2002 17:25:35
 Re: Re: SC with a dead short in reply to howard, 05-05-2002 15:55:01
Thanks Howard, I tried that and they were okay. Turned out the Ampmeter had shorted out internally. Guess I should've expected that it's only 51 years old. Replaced the meter and all is normal and a-OK!. Will take a month to grow back all the hair I lost over that one...FB
