Farmall B-Battery/starter
Tom Welch
05-02-2002 12:07:58
I'm looking to buy a Farmall B and as I can recall it has a starter but no battery.Is this a standard configuration or is the battery just missing?Also there is no generator and it looks as though there never was.
gene b
05-03-2002 04:27:50
 Re: Farmall B-Battery/starter in reply to Tom Welch, 05-02-2002 12:07:58
youre look at a tractor that was built before AUGUST of 1947 hard to tell what has been removed of added serial number of the engine will tell when engine was built also the plate on the seat bracket iff still there other codes are casting codes and you dont know iff those are original get a book and start redoing it a great little tractor
Red Dave
05-02-2002 12:34:19
A Farmall B could be bought new with or without a battery and starter. Some very early ones didn't even have a place to mount the starter in the bell housing.
There isn't much use for a starter without a battery unless you plan to jump it from a battery every time you want to start it.
You can tell if it had a generator by looking at the pulley on the fan assembly, if it is a double pulley, it proably had a generator at one time. If the pulley is a single sheave, it didn't have a place to drive the generator.
Who knows what someone might have changed over 50+ years.
