Distillate
Hal Davis
04-30-2002 13:09:06
What is distillate? My guess would have been Kerosene, but since there is a kerosene engine, distillate must be different.
Mudcat49
05-01-2002 19:34:12
 Re: distillate in reply to Hal Davis, 04-30-2002 13:09:06
3/5 kerosene 2/5 gas, mixed IE 5 gallons: 3 gallons kerosene 2 gallons gas But now-days kerosene cost as much as gas!! so most people just run straight gas.
Hal Davis
05-01-2002 09:32:18
Thanks to all who responded.
randy hall
04-30-2002 20:32:46
distilate is between kerosine and gasoline. standard oil used to call it power fuel, used mostly for low compression put-puts
Michael Soldan
04-30-2002 18:38:39
Distillates were any kind of bi-product of the petroleum industry, kerosene, stove oil, diesel and furnace oil and in days gone by distillate was somewhere close to kerosene and it burned well in distillate tractors set up with shutters, a heat shield and the two tank system, the small tank for gasolene to start up on and the main tank for distillate once it was at "RUN" on the heat guage. Remember there were other brands of tractors that would even run on used motor oil as a distillate. Today's kerosene is refined far more than in the old days but it won't hurt to run it in a distillate tractor , it is still less volatile than gasolene. Mike in Exeter Ontario
Steven@nd
04-30-2002 15:25:30
I think distillate was in between kerosene and diesel fuel-probably closer to diesel. Distillate engines will run fine on kerosene.
Steven
Russ
04-30-2002 15:04:33
I have heard JP5 is very similar
SAm in NS
04-30-2002 13:26:46
I believe distillate is similar to Kerosene but I think that it is a more general term. SAm in NS
steve
05-01-2002 18:40:38
 Re: Re: distillate in reply to SAm in NS, 04-30-2002 13:26:46
75 gallons of kerosene and 25 gallons of gasoline was the cities service formula in indiana in the 1940' abd 1950's.
k-j
05-04-2002 16:36:50
 Re: Re: Re: distillate in reply to steve, 05-01-2002 18:40:38
But will the head fit an reguler tractor?
