This Sounds Expensive
Jim
04-23-2002 08:57:12
My '45 Farmall H is making an expensive sounding noise. It is a solid snapping noise made while underway in any gear. I was thinking it was coming from the front bolster area, but I fear it could be coming from under the deckplate, only I don't feel it in the seat of my pants as I drive, I hear it and it sounds like it comes from up front. The wheel bearings are good, I replaced them last year. This is pretty limited and lame information, but any assistance on where to go from here to diagnose this problem would be appreciated.
steve
04-23-2002 19:34:19
 Re: This Sounds Expensive in reply to Jim, 04-23-2002 08:57:12
does it click each time the front wheel goes thru one revolution, each time the rear wheel goes thru one revolution? or does it happen faster in 1st gear than in third. if so it is related to the transmission or rear end. doe sit change with engine speed, not ground speed? may be engine --clutch related?
PatM
04-23-2002 10:37:48
Redbaron could well be right! Bolts loosened up on one front wheel of my M and wallowed out the cast center before I figgered out what was up! Took less than a half hour. Ruined the center and my day.
redbarron
04-23-2002 09:14:12
Hi Jim
Check all of your wheel bolts, If one is a little
loose they will make a snapping noise like you describe,have had that happen to me before. luck RB
Jim
04-24-2002 06:04:07
 Re: Re: This Sounds Expensive in reply to redbarron, 04-23-2002 09:14:12
I checked the mounting bolts and found all three loose on the right front rim. Thanks for the info. This is a great forum.
Dan Kelley
04-23-2002 14:55:11
Cool. I hadn't even thought of this solution. My M's front is making a clicking noise that I could feel in the steering. I just assumed it was front wheel bearings, but this makes more sense. I've got brand new front tires. I'll check these bolts to be sure they're tight. Maybe, I'll be able to save my wheel-bearing and seal money for some other worthy project.
What a GREAT web site!!
