Is it possible......
Greaseman
04-06-2002 08:58:56
Is it possible to put a three point hitch on my Super C which doesn't have a Quick-Hitch? Or how difficult will it be to put a quick hitch on my machine?
Haas
04-06-2002 16:46:39
 Re: is it possible...... in reply to Greaseman, 04-06-2002 08:58:56
You can buy a 3 point hitch from Saginaw County Tractor that will fit your Super C. They also have the block and control valve to tie into the hydraulic system to work the cylinders.
ScottyNY
04-06-2002 11:11:55
The hard part of a quick-hitch will be finding one that someone is willing to part with it. If you can get hold of one and then a 3-pt conversion, that will work well for you. For straight 3-pts, there are several companies that make them for the SuperC. Two that come to mind are C & D and Saginaw. The C&D operates off the Touch Control lift arms. It's basic, but well made and sturdy. The Saginaw, as near as I can tell, operates off a cylinder, as does the quick-hitch. If you already have the remote control hydraulics on your tractor, you should be set to go if you get the Saginaw. I gathered from a thread a while back that Saginaw can provide the spool valve and controls to add a remote control if you don't have it. (I may be wrong on that--perhaps someone who has experience with it can jump in here.) In any event, you can get parts to add the remote if you decide the Saginaw is better suited to your purposes. Hoping this helps. Scotty
Hugh MacKay
04-06-2002 09:16:31
Fast hitch off any Super C or 200 will fit right on your tractor, just make sure you get the hydraulic valve that operates the hitch cylinder. If you want a straight 3 point hitch look at Dave Id post a bit further down this page, quite simple set up and he is going get rid of it. It will however not lift as much weight as the Fast Hitch with 3 point adapter. There was also a Fast hitch in photo adds about 3 weeks back, might still be there.
