Valve adjustment
woodmaster
03-18-2002 10:35:12
got about 20 hours on newly rebuilt motor in my 560 G.should I adjust the valves?I am going over everything such as clutch,T/A and so on.Of course new filters & oil.If so what should the valves be set at?cold or hot? or should I just go by the I&T manual?Thanks ahead of time,Larry
Matthew
03-18-2002 16:49:10
 Re: valve adjustment in reply to woodmaster, 03-18-2002 10:35:12
Do it by the book. Run, Re-torque, and Re-gap!
Phil Auten (Tx)
03-18-2002 11:02:47
Larry,
Before adjusting the valves, I would recheck the head bolt torque, engine cold. Then warm it up to operating temp and check the valve clearances, setting to specs if required.
Phil
