A Engine Questions
Mike
03-02-2002 14:02:33
The engine on my A has C-123 cast on the block by the mag, so I thought it was a 123 engine. When I tore it down, The sleeves measure 3 5/16 at the seal area. I thought it was a 123 engine but it must be a 113. Also I had to grind the crank 20 on the rods and 30 on the mains. Is that OK or should I think about another crank? Mike
Dave G
03-02-2002 16:34:51
 Re: A Engine Questions in reply to Mike, 03-02-2002 14:02:33
What does the bore measure? If 3.0 inches then 113. If 3.25 inch then 123. I have a engine with place for hydralic pump and I know it is a 113.
Mike
03-02-2002 16:58:17
 Re: Re: A Engine Questions in reply to Dave G, 03-02-2002 16:34:51
The Bore measures 3 1/8 but you can get sleeves for a 113 that are that size. I think it must be a 113, but I dont know why the block has C-123 cast into it. Thanks Mike
Steven@nd
03-02-2002 15:15:09
Your crank will be fine. These tractors are tough and overbuilt for thier power.
Steven
charles(TN)
03-02-2002 14:47:42
Does the engine have place for hydraulic pump under the ignition. If it does is a 123 engine, a 113 block has no place to mount a pump.
Mike
03-02-2002 15:07:03
 Re: Re: A Engine Questions in reply to charles(TN), 03-02-2002 14:47:42
Yes, there is a place where it looks like a pump could go. There is a cover over it, but when you take the cover off you can see the gear. But when I ordered sleeves for the engine, they told me to measure the seal area of the sleeve. If it was 3 5/16 it was for a 113, if it was 3 7/16 it was a 123 and mine is 3 5/16. whats going on????
Red Dave
03-02-2002 16:10:22
 Re: Re: Re: A Engine Questions in reply to Mike, 03-02-2002 15:07:03
Starting in '48 Super A's and C's had C-113 engines with a hydraulic pump. Sounds like you have one of those blocks on your A.
I don't know why it would have 123 cast on the block.
Mike
03-02-2002 16:16:28
 Re: Re: Re: Re: A Engine Questions in reply to Red Dave, 03-02-2002 16:10:22
Thanks for the Info
