Grandpa's old I-544
Don
02-25-2002 09:33:45
I just inhearited my Grandfathers old International I-544 gas tractor. It is presently not running but all there and did run 18 months ago. I am looking for others with tractors similar to mind to ask a ton of questions that I have.
This is my first tractor so I am learining as I go. I do know form the serial numbers it is a 1968 build I-544 gas. It has power steering (what I pain in the butt moving when not running. Had to actually turn the wheel by hand as steering wheel does not work without power). Appears to have front and rear hydrolics with a 10 speed transmission ( 4 forward/1 reverse with hi/low lever).
Any help would be greatly apprecheated. Thank you.
Don
02-26-2002 05:13:50
 Re: Grandpa's old I-544 in reply to Don, 02-25-2002 09:33:45
Steve was nice enough to post some pictures I sent him of two question spots on my tractor. The first is of the left fender. Is this were the batter was supposed to be mounted. All I have is a bungie cord. Was there a battery bracket that I am missing? The next picture is of my console. It has a few holes in it am I was wondering what is missing? The two large guages have the "IH" logo on them. The amp and oil pressure quages look aftermarked. I have two holes that looked like they housed lights on the dash and there seams to be a lower panel that is missing.
If any one has pictures of the thier consoles I would like to see them to compare. Thank's again Steve for posting the pictures for me.
Don
02-26-2002 05:07:59
Last night I hooked a battery to my tractor to see if the lights of the dash would work. They did and were green. Anyways while I was hooked up I hit the start button. The Engin turned over. I was very excited about this. I only let it turn a very short time. Is there something I should do to the engin before I try to start it due to it sitting for 18 months. I am thinking I should take out the spark plugs and put some oil in the cyclinders to help loosen them up, but I also do not want to damage my engin if this is not a good thing? What do you guy do after a long storage of your tractors before you start them?
John in Maryland
02-25-2002 14:16:05
I have run both a row crop and a utility 544, and both had 5 gears.
R-2-4
1-3-5
neither was shuttle both had T/A. I guess it is a wide front. A word of caution, if it is like a 656, in "Low" with the t/a, it will free-wheel down a hill. Just to let you know so you don't find out the hard way.
Don
02-25-2002 14:30:02
 Re: Re: Grandpa's old I-544 in reply to John in Maryland, 02-25-2002 14:16:05
What is the difference between the row crop and utility?
Don
02-25-2002 14:29:57
Steven@nd
02-25-2002 10:04:14
I have a Farmall 544 which should be fairly similiar if you have any specific questions. Mine has 5 forward and reverse speeds. It has a shuttle instead of the Torque Amplifier. Another version of the 544 transmission was the hydro.
I believe they have a C200 4 cylinder gas engine. It is sleeveless so an overhaul requires removing the block and boring if it is too worn. The tractor is a very handy size, but the engine is very touchy on carb and point adjustments. If you do get it running and it runs erratically check the manifold, they are prone to vacuum leaks.
Steven
Don
02-25-2002 14:32:13
 Re: Re: Grandpa's old I-544 in reply to Steven@nd, 02-25-2002 10:04:14
Did you get the pictures I sent to your E-mail address? Is there a difference between a Farmall 544 and an International 544. My tractor has International in diecast letters on the front. No Farmall decals or emblems.
Steven@Nd
02-25-2002 15:53:35
 Re: Re: Re: Grandpa's old I-544 in reply to Don, 02-25-2002 14:32:13
The row crop or Farmall versions of tractors were higher up off the ground, there is more clearance under the axles and the wheel tread width is adjustable so it fits through the rows of crops like corn or tobacco.
Utilities are low slung, low center of gravity tractors, usually used for loaders and backhoes.
I got your pics and can't help you with your gauges other than it looks like there should be a tin over the control rods below the dash.
Here are the pics for everyone else though.
Steven
third party image
third party image
RPM
02-25-2002 09:47:51
Steering was designed to have some control even if engine was dead or died during use (like running out of fuel), yes it turns hard but it can be done. Its a 4 cyl version of 656 tractor.
Don
02-25-2002 14:33:52
 Re: Re: Grandpa's old I-544 in reply to RPM, 02-25-2002 09:47:51
What was a 656? Is it a 6 cylinder version of the 544?
RPM
02-26-2002 07:31:02
 Re: Re: Re: Grandpa's old I-544 in reply to Don, 02-25-2002 14:33:52
Yes
jeremy
02-25-2002 09:44:14
My dad has a 544 he got it two years ago when we got it it only 2800 hours on it. It is in perfect shape. If you have any questions you can ask I might be able to help you out.jeremy
Don
02-25-2002 14:27:45
 Re: Re: Grandpa's old I-544 in reply to jeremy, 02-25-2002 09:44:14
Thank you for your response. I have a few questions
1. Where does the Battery go? I think the left fender but I am missing a bracket to hold it down if that is where it does go.
2. What guages are supposed to be in the console. I have some holes.
3. What is the front grill supposed to look like, I have chicken wire?
4. Is it possible to rebuild the fuel pump or does it need completely replaced like a automoble.
Any help is apprechated.
