Farmall A Transmisson Problem
Pete
02-19-2002 14:36:32
took the top off of our transmission case to take a look in and found out that one of the gears of the bottom half of the tranny was missing some teeth and that the differential moves from side to side against the pinion gear and was wondering if I should try to find a used tranny or maybe replace the bearings and the bearing retainers. Someone had suggested that the tranny case was worn out and that was why the differential had so much play. Thanks for any suggestions
Farmall-Nut
02-19-2002 15:49:15
 Re: Farmall A Transmisson Problem in reply to Pete , 02-19-2002 14:36:32
Pete,sounds like the problem began in the tranny and so then wore out your bearings.Just fixing them won't gain you much time and may cost you more down the road.
