706 3pt Won't Lower
Don
02-11-2002 06:19:12
The factory three point hitch raised all the way up and now wont' lower. It only had about two hundred pounds on it, but I dont want to add weight to try to force it down and break something. I hope it to be a valve in an easy location to replace. Any ideas what could be wrong?
Nate
02-11-2002 13:46:29
 Re: 706 3pt Won't Lower in reply to Don, 02-11-2002 06:19:12
Make sure your draft control lever isn't in the extreme light position.If the lever is past the second mark from the end this will not allow it to lower
Jim
02-11-2002 07:51:02
What you need to check is the arm that goes to the load control shaft. To check this take off the 3rd link cover and look on the right side of the case. There is an arm that comes up from the bottomof the case along side of the PTO. And there is an other spring loaded arm that comes down from the top. Check to see if the top arm is to the back of the lower arm. The spring loaded arm slips past the other arm and the 3pt will not go down. To get the arm back. I take a rope and go around the top arm and get someone to help you pry the lower arm over and pull the upper arm by . If you have any questions email me
