The M will (as mentioned in the other post) seem a little primitive compared to the 460, but things like the shift pattern will be the same, and overall it will feel somewhat familiar. Depending upon what has been done to the M in its lifetime, and its condition, you may find it to have every bit as much pulling power as the 460. If the 460 can power the blower, the M will likely handle it, and the lifting power of the loader will depend on the diameter of the cylinders and how much pressure the M hydraulic system develops. A "live" hydraulic system is what you have on the 460. It keeps working when the clutch is pushed, unlike the system that came on the M, which stops pumping when you push the clutch. Live hydraulics can be added to an M (if you're lucky it as been) but the original system can lift a surprising amount with a front loader if the pump is in good shape. Depending upon loader design, and pump pressure, a small round bale is not out of the realm of possibility. If the M does not have power steering, loader work gets tiresome in a hurry. The mower will likely not fit the M, but they are very versatile tractors which continue to be a very useful, user-friendly, and enjoyable piece of machinery. Good luck with yours!
