WD40 Rods
Redfan
07-01-1999 06:12:34
I have a WD40 motor pulled down and after the trouble I had getting the pistons out past the crank,I'm not looking forward to putting them back in the same way. It's been suggested to me that it is possible to machine a tiny amount off the Rod big end which would allow it fit back in the Sleeve in the more conventional way, from the top.Any information on this one. Another option ,I guess,is to press the sleeves out and replace the piston and sleeve as one unit. Any help appreciated.Redfan.
mark
07-01-1999 11:01:38
 Re: WD40 Rods in reply to Redfan, 07-01-1999 06:12:34
try to put the rod with out the piston in from the bottom then piston & pin on the top push the assambly down from the top.
