22-36 Belt Pulley.
Redfan
06-20-1999 05:39:11
I have a 1929 22-36 that is going to need a lot of work.Two questions; Did they have the E4A Magneto or a Bosch ZU4, or either;Will the Belt Pulley assembly from a WD40 fit. I know the 15-30 Assem. does'nt fit. Any advice would be appreciated. Thanks.
R Rahmier
06-20-1999 18:20:42
 Re: 22-36 Belt Pulley. in reply to Redfan, 06-20-1999 05:39:11
I just bought a 22-36 today it has a E4A mag on it
everyone has told me that a 22-36 is identical to
a 15-30 except it has a bigger bore and more RPMS
by the way can any body tell me how you set the
breaker point gap because the impulse wont let you
and what the gap is thankyou
Redfan
06-21-1999 01:36:11
 Re: Re: 22-36 Belt Pulley. in reply to R Rahmier, 06-20-1999 18:20:42
You should be able to release the impulse coupling, allowing you to set the points. On the Mag. with a BH or BX Coupling, at the drive end of the Mag. is an exposed Pawl which can be released with your finger and on the automatic type coupling, release and slide forward the cover which reveals the tail end of the pawl. Press down on this pawl any time you want to turn the Mag. over by hand. The point gap is 12 to15 Thou. Hope this is some help.From my information the only other main difference between these two tractors was the inclusion of a water pump on the 22-36.
