450 Hitch
Gary (UT)
05-15-1999 11:30:40
I have a bar at the rear left of the deck plate on the 450D that connects to the hitch and adjusts up and down. I don't understand how it effects the hitch or when and how to use it. Thought I'd go to the source of all knowledge (are you there Red?) to find out. Appreciate the help and all the good information on the board.
RAW
05-15-1999 16:16:40
 Re: 450 Hitch in reply to Gary (UT), 05-15-1999 11:30:40
That lever is a traction control lever for the fast-hitch when used with mounted equipment. We had a 350 with a mounted plow and dad left the lever locked out because it made the plow change depth every time the soil conditions changed. We never couldmake it work very well.
Lynn (Ia)
05-15-1999 18:37:39
 Re: Re: 450 Hitch in reply to RAW, 05-15-1999 16:16:40
The flat bar is the draft control for the fast hitch. In theory it will raise the hitch when the load increases & lower back to the preset depth when the load returns to normal. I have it on a 460D and can't really say that it works very good.
