SMTA V8
Tan67
06-17-2007 20:35:21
has anyone seen the farmall super mta with v8 on it??? it has roll cage, runs on alcohol, 18-4-38's personal built wide front, has no t/a but once was a mta made into a v8 pulling tractor, then the t/a was removed small block chevy, should be in virginia some wher. please reply if you have encountered it!!! last i saw it was unpainted.
Aaron B
06-18-2007 05:22:58
 Re: SMTA V8 in reply to Tan67, 06-17-2007 20:35:21
I have seen an M at a couple pulls here in WI, has a 455 Rocket V-8. This may be a more common conversion than you think.
gene bender
06-18-2007 03:03:59
A modified M can be found all over this country with many different engines used.
Tan67
06-18-2007 06:24:21
 Re: SMTA V8 in reply to gene bender, 06-18-2007 03:03:59
my brother biult the MTA v8, i was just wandering if antone had seen it.
