Serial number
MTJC
06-17-2007 20:03:32
Hi guys need some more advive.I bought a Farmall M with no serial tag on it.Any way to find out what year it is?Thanks Mike
CHIEFEAVES
06-19-2007 14:27:47
 Re: Serial number in reply to MTJC, 06-17-2007 20:03:32
IF THE ORIGINAL MOTOR IS IN IT. THE SERIAL NUMBER WILL BE MOLDED ON IT. MY 39 HAS IT BEHIND THE MAG.
georgeky
06-18-2007 07:31:06
There are casting codes an all major components, such as axles, engine block and so on. They will read like this 3-21-Z or something of that nature. Each year used a different letter. It is on a small tag riveted to each part. So when you find that post it and someone can tell you what year it is. You might look on the right frame rail for the serial number.
