Order Farmall Cub Parts Online
cub
Cris
06-13-2007 18:56:57
I am thinking about buying a1955 Cub and have some questions (sn192269) First is the grill suppose to be white or red? I have seen pictures both ways. next how do you check the oil level in it,I have not seen a dipstick or the petcocks on he oil pan (like my Super A has) and last it has a 42 in Woods bellymower on it and the whole outfit seems to be inreal good condition,Is $1500.00 a reasonable price?
Thanks
C. Phillips
08-07-2007 13:16:16
 Re: cub in reply to Cris, 06-13-2007 18:56:57
I'm looking for a 3 or 5 bar grill that will fit my 1949 Farmall Cub. Any suggestions?
Jim Becker
06-14-2007 07:19:58
You need to read this befor you buy it.
Nat 2
06-14-2007 06:04:54
The dipstick is supposed to be riveted to the oil breather cap behind the carburetor on the left side of the engine.
You've "seen them both ways," no. The ones with the white grilles are 1957-1958 models. Cub grille styles changed along with the bigger tractors after 1954.
billde
06-13-2007 19:33:47
Also the correct grill is the 11 bar.
Daniel Robertson
06-13-2007 19:26:49
Grille is Red. Oil check is part of the oil fill cap located near the carb. $1500 is a good price if you're buying, not so good if selling. I wouldn't take twice that for my 1955 cub.
billde
06-13-2007 19:23:55
Hood panels and grill are red,dipstick is right behind carb. 1500 is very reasonable assuming it is in running order without major faults.
