Bn steering shaft removal help
Scott Joseph
06-13-2007 06:56:22
I need to get the steering shaft off my 47' BN and can't figure out if the knucle(u-joint) is bolted to the worm gear shaft or if it's held in by some sort of pin. I need to do this to remove the bolster. Any help would be great. Thanks
Clefus
06-13-2007 19:39:30
 Re: Bn steering shaft removal help in reply to Scott Joseph, 06-13-2007 06:56:22
Is the u-joint/knuckle still available ??
I have a '46 BN and it had pins I had to drive out....I ended up putting it back together because I needed the tractor..
Red Dave
06-13-2007 07:24:30
It is held on by a pin. The one on my B uses a cotter key.
