SH govornor questions...
Matthew(Mich)
06-01-2007 11:02:17
My super H doesn't want to idle down. The thottle plate is closing like it should. I feel my problem is in the govornor. I removed the top cover the one that has the vent tube. If I push down on that rod and hold it for 5sec it idle's great and will remain idle like it should. Once I advance the thottle and then push the thottle back down to an idle it just won't idle down like it should.
All the linkage is moving free and I removed the side cover to the govornor and cleaned all the moving parts really good but still doesn't idle low. The govornor is working when I load the tractor like it should.
Any thoughts guy's????
Bob M
06-01-2007 12:42:04
 Re: SH govornor questions... in reply to Matthew(Mich), 06-01-2007 11:02:17
When I first got it my SH had exactly the same problem.
Fix is to adjust (shorten) the throttle shaft bellcrank under the vent tube cover.
Remove the cotter pin and pivot pin, then loosen the locknut and give the bellcrank a turn or two clockwise on the connecting rod. Then put the pivot pin back in and run the engine - it may take two or three to find the correct adjustment so it idles down correctly. Finally reinstall the cotter pin and gently tighten the locknut.
Tip: Be careful to not drop the cotter pin or bellcrank pivot pin down the riser tube!
