Oil preasure on os-6
Hand Crank
05-29-2007 10:35:56
Just put a new oil preasure gauge on my os-6 and when I started it up it pegged the needle all the way to the right.Is this normal or do I have a problem? Thanks,Don.
John M
05-29-2007 15:55:26
 Re: Oil preasure on os-6 in reply to Hand Crank, 05-29-2007 10:35:56
Which gauge? Does it drop some when it warms up? Whats the condition of the engine? My 41 M will run all the way up until it gets warms.
janicholson in LA
05-29-2007 13:44:47
The oil pressure should be checked with a master gauge. if between 60 and 75 it is great. Just use a gauge with a greater range. If over 75 the relief is stuck, Pulling the pan is access to the pump. JimN
lawmar
05-29-2007 11:25:25
What kind of gauge? What is the top pressure of the gauge? Most of these 248-281 motors I have seen will run at 60 lbs of oil pressure. If you have way more than that your pressure relief valve in the oil pump could be stuck.
