Order Farmall Cub Parts Online
Cub Cadet Lowboy 185
Jim9178
05-22-2007 15:58:35
Help with Lowboy 185. Were is the hydraulic fuild filled from? The guy I bought it from said he just filled it by taking the filter off and filled it there. I looked in Manual but did not see it in there.
Bill Geer
05-22-2007 21:52:00
 Re: Cub Cadet Lowboy 185 in reply to Jim9178, 05-22-2007 15:58:35
Jim On the back of the rear axle there is a oval shaped cover. should be a pipe plug[takes a 3/8 ratchet]
take it out and fill till it runs out of that hole. Use hy-trans only. If you have a 3 point hitch or a mower you may have to remove gards. Bill
