Re: Power steering unit--Behlen
john d.
05-06-1999 17:42:23
Don't know what the value might be, but someone out there would probably pay several $$ for it! Those things were used extensively on M-SuperM models, and some H-SuperH tractors as well as other brands. The unit had 3 main parts plus hoses and mounting brackets. A fairly small hydraulic pump was installed in front of the distributor for power, there was a reservoir tank that mounted in front of the gas tank, under the hood, on the right side. The part you describe is the actuator, and does the work. It was installed by cutting the steering shaft a few inches in front of the light bracket and then coupling the shaft ends to the actuator unit.
These were very dependable units as long as you keep oil in them. I've got one on a Super M that's served well for over 35 years.
Sam
05-06-1999 19:13:40
 Re: Re: Power steering unit--Behlen in reply to john d., 05-06-1999 17:42:23
Give you $25 for it. The value would be $350 guessing. If it s all there and working.
tom
05-06-1999 18:03:34
they were used on farmall 400 and 450.
