806 - no start
IN
05-10-2007 17:48:06
Have a 806 diesel that will not turn over. Batteries checked and are good . Lights work. When the key is turned on the oil light that usually lights up does not. Hit the push button and nothing.
Sign of a bad switch???
Brownie450
05-10-2007 19:53:09
 Re: 806 - no start in reply to IN, 05-10-2007 17:48:06
Does it turn over when you jump the solenoid terminals? If it does, your problem is from the ign. switch--starter switch---clutch safety switch--- possible solenoid small wire connection. Our 1066 had this sort of goings on, & it turned out that the heavy battery cable was eaten out where it attached to the big terminal on the solenoid. Cleaning the cable end, & putting a "star" washer plus the lock washer on the stud solved the problem. Hope yours is that easy.
chadd
05-10-2007 18:51:59
Yep, sounds like the key switch itself or one of its wires. I am pretty sure that the starter will not operate if the key doesn't work, because then the clutch switch wouldn't have power either.
