decals
LinemanFarmer
05-04-2007 05:09:43
I would like some opinons in buying decals. Im not quit finished painting the M but its getting close! I have been useing hardner and it is making the paint a little more glossy. What is the best way to go, Mylar or Vinyl? I figure you see the clear coating on the Mylar but is the Vinyl individual letters where I could possibly get them on a little out of shape?
Thanks Derek
CNKS
05-04-2007 18:53:28
 Re: decals in reply to LinemanFarmer, 05-04-2007 05:09:43
I prefer the vinyl, easier to apply, and it does not become discolored with age. It is not original, but neither is the acrylic urethane paint I use. I am not a purist. I don't understand your "out of shape" question. It is a lot easier to mess up the mylar than the vinyl, particularly if you only use it every 2 or 3 years as I do.
IH2444
05-04-2007 16:35:02
Umm I checked and mylar has only been around about 40 years....
Lance in Brenham, TX
05-04-2007 08:42:35
Mylar - it's factory, baby!!
RustyFarmall
05-04-2007 05:47:28
If it was good enough for IH when the tractor was new, then it's good enough for me now, but it's your tractor, and I'm not going to tell you what is right and what is wrong. I have found that the clear backing on the mylar will pretty much disappear over time. It helps to park the tractor out in the hot sun after it is done. I can still see the clear coating, but it is not nearly as noticeable now as when I first applied them.
brainerd dave
05-04-2007 05:35:39
Mylar was factory, but I prefer the vinyl. They were much more expensive, but I like the look. It's pretty hard to get them out of shape if you're careful putting them on. The small print below the large letters "McCormick-Deering Farmall" of the vinyl set I have is still mylar.
As always, opinions vary.
IH2444
05-04-2007 11:36:22
 Re: decals in reply to brainerd dave, 05-04-2007 05:35:39
We had mylar in 41 ?
