Char Lynn steering system
JKF
04-27-1999 12:00:14
Two years ago I put a Char Lynn steering unit on my 400 farmall.I have not been really happy with it bot was a whole bunch better than nothing.The last two times I used it the pump got boiling hot.I took the filter out a replaced the fluid with Dextron 111. Any ideas would be helpful Thanks Jeff
Jim
04-28-1999 07:17:44
 Re: Char Lynn steering system in reply to JKF, 04-27-1999 12:00:14
Was it a new unit or used. If it was used I would guess that your pump is bad.I have a source for rebuilt Eaton pump.
Jim
04-28-1999 10:25:37
 Re: Re: Char Lynn steering system in reply to Jim, 04-28-1999 07:17:44
Also have you run a presure test on the pump to see how it is.
Brian
04-27-1999 16:39:10
I have a similar problem with a char-lynn on my Super MTA. It works great until it gets warmed up good and then it seems to get pressure in the bowl and leaks. It also steers sometimes harder than if i didn't have power steering when it gets warm.
