Super M RPM Range
Wanna be farmer
04-25-1999 18:32:51
From idle to full throttle, my engine doesn't sound like its peaking out. Can anyone give me a rpm range from idle to full throttle?
Ronnie
04-26-1999 05:28:08
 Re: Super M RPM Range in reply to Wanna be farmer Jeff, 04-25-1999 18:32:51
Jeff get a hand held shaft tack and put it on the PTO shaft and it should turn 585 R.P.M. no load (fast idle). That should have the motor running at 1600 engine R.P.M. Low idle is 625 engine R.P.M. and 230 R.P.M. on the PTO shaft.
Bob M
04-26-1999 05:06:15
My Super M runs 1,600 RPM at full governor and no load - which incidentally matches the "max idle speed" marked on the serial no. tag.
Low idle is 375.
Phil Auten
04-26-1999 04:48:57
Jeff,
Maximum governed RPM on a Super M is 1450. These old tractors rarely run at over 2000 RPM, they use torque, not HP to do the work and max torque RPM is where they are governed to.
Phil
