560 hydraulic issues
Ed560
03-07-2007 23:45:07
The front end loader on my 560 has become very weak and slow. I put in a new hydraulic filter and 15 gallons of IH hytran to try and take care of the problem but that didn't work. The power steering works good and the 2pt. hitch seems to be working fine(although I haven't tried to pick anything up with it). Is there a pressure relief that only controls the center and left hyd. valves? It worked fine at the beginning of winter but now it's not. Any suggestions??
Allan In NE
03-08-2007 02:45:51
 Re: 560 hydraulic issues in reply to Ed560, 03-07-2007 23:45:07
Ed,
Do you have a separate heavy implement that you could plug into those same ports to test?
That would tell you if the problem lies with the tractor or the loader.
Allan
Hugh MacKay
03-08-2007 00:59:23
Ed: If the hitch is working well and loader not, first place I'd look would be quick couplers for the loader. Worn couplers can restrict oil flow. The same pressure relief valve will control all three valves.
You could also have bypassing within the loader cylinders, they may need rebuilding. Best way to check your cylinders is leave the loader up for a spell. If it settles you have bypassing.
