Farmall regular clutch
jeff
04-10-1999 05:21:59
How do I pull the clutch out of my farmall regular? After I take the cover off should it just slide off or what? Its basically a big clump of rust so I can't tell how its in there.
C.Fitz
04-11-1999 03:49:26
 Re: Farmall regular clutch in reply to jeff, 04-10-1999 05:21:59
You should see 6 bolts around the outer edge of your clutch plate. Take every other one out; leaving 3 still holding your clutch plate on. On your clutch plate you should see 3 half-inch holes with no bolts in them. The 3 bolts that you have already removed go in here and tighten them up ; as you are doing this you should see your clutch springs re-tracting. Keep tightening until all 3 clutch spring fingers are fully retracted. Now all you have to do is un-bolt the remaining 3 bolts along the edge and your clutch will come right out. Good luck.
Jeff
04-12-1999 13:20:25
 Re: Re: Farmall regular clutch in reply to C.Fitz, 04-11-1999 03:49:26
Thanks for your help, but I think you are talking about the later style clutch, early Regulars and 10-20's had a 5-disk clutch, it has one big spring in the center, I should have specified that in my message.
