Cracked head??
Sly
03-19-1999 15:53:46
I suspect the Super "C" I just recently purchased has a cracked head. When I first got it I changed oil, but noticed no antifreeze in the oil. The tractor runs great. Is there another way to check for a cracked without tearing it a part??
Peter
03-09-2000 16:18:08
 Re: cracked head?? in reply to Sly, 03-19-1999 15:53:46
There is a kit to check for combustion by products in the radiator avialible at NAPA stores and elswhere. this will tell you if the antifreeze is coming from the head/head gasket or sleeve. If it checks bad get a spark plug adaptor and rotate each piston to TDC. Fill the cyls w/air one at a time, on the damaged cyls water will blow out the radiator.
If there is no combustion by products, drop the pan and pressurize the rad. Water will likely leak from the sleeve o-ring or elsewhere.
I just opened Advanced Cast Weld Inc. I have 22 years experience and I am a ASE Master Engine Machinest. (I repair broken castings!)
Peter Sattler
337-457-0908
Milan D. Radakovic
03-20-1999 14:53:04
Try doing a compression test, if the pressure falls off after a bit of time, it's got a leak.
Phil Auten
03-19-1999 17:48:15
Sly, With the tractor running, remove the radiator cap and check for bubbles in the coolant. This will indicate a leak between combustion pressure areas and the water jacket. Could be a cracked head, a bad head gasket, cracked sleeve or something worse. The only way to tell for sure is to have the head "Magnafluxed" by a shop. This will tell you for sure if the head is bad. Even the tiniest crack will show up in the Magnaflux process.
Good luck,
Phil
