Re: I Am Still Confused About 12 Volt Generator Conversion
Steve R
01-20-2002 16:45:58
Your voltage regulator and generator have to be of the same voltage.You will have to get a 12 volt generator or have yours converted.
Irv
01-20-2002 17:00:10
 Re: Re: I Am Still Confused About 12 Volt Generator Conversion in reply to Steve R, 01-20-2002 16:45:58
I thought the same thing, until I read some posts on this forum. The generator it seems is a generator, it doesn't know anything about voltage. The regulator does just that. I converted my H by putting on a new regulator, and changeing the bulbs, etc. The question I have is why alternators replaced generators? I am sure somebody here knows. Irv
Jim T
01-20-2002 17:08:23
 Re: Re: Re: I Am Still Confused About 12 Volt Generator Conversion in reply to Irv, 01-20-2002 17:00:10
Irv, the biggest advantage of the alt. over the gen. is the alt. puts out max. voltage at all RPM while the gen. must be at max. RPM for max. voltage. Idleing your tractor with a gen. will not recharge your battery where an alt. will. Jim T
C.George
01-20-2002 18:58:43
 Re: Re: Re: Re: I Am Still Confused About 12 Volt Generator Conversion in reply to Jim T, 01-20-2002 17:08:23
Jim, Also an alt.will have much longer brush life as they have a continous slip ring vs. a segmented communtator on a generator.Also they are so much more trouble free compaired to gen./reg. set up
