Farmall C PTO shifter lever question
andy
01-10-2002 21:36:43
I am repairing and painting a Farmall "C". The PTO lever turns in the shaft coming out of the PTO. Must be a roll pin missing that holds it tight. My problem is this ..... is the rod that you move to turn on and off the PTO subposed to be straight or curved? It is sort of a 3/8 inch diameter rod .... must be 8 to 10 inches long (guessing). If it is curved does the curve go forwards or backwards? Thanks ... andy
andy
01-13-2002 11:02:55
 Re: Farmall C PTO shifter lever question in reply to andy, 01-10-2002 21:36:43
Yep ... my lever is bent back too. Thought the hole might be for a rollpin rather than a cotter pin. Thanks for the replies.
Bob/Maine
01-12-2002 05:36:41
Hi Andy, Mine was bent just a little but, I bent it more because of the after market 3 point hitch being in the way. It has a cotter pin hole in it to keep it from turning. Bob
Mark A
01-11-2002 05:02:33
Mine is curved backwards, my guess to clear the tool box.
Toyfarmer
01-10-2002 22:53:14
Andy,
There should be a cotter key holding the shaft in place and it's slightly bent backwards.
Toyfarmer
