Case International 5140
Tim
01-04-2002 18:56:16
5140 goes to neutral at anytime. Push in on the clutch and release clutch and it will go maybe. If you hold the clutch just off of the lower clutch switch everyting is okay. I have replaced both clutch switches. The tractor has a scynromesh transmission. What can be causing it to go to neutral?
John M
01-06-2002 16:31:55
 Re: Case International 5140 in reply to Tim, 01-04-2002 18:56:16
Sounds like a bad relay. Check your operator`s manual for location. I`ll look at a shop manual tomorrow also, & get back to you.
kev@ia
01-05-2002 07:05:16
Here is a link to a forum that deals with modern tractors, Machinery Talk at @griculture.com.
farmer kev
