Tach repair.
gibby
01-02-2002 13:22:43
Where is a good place to send my tach to be cleaned and lubed. It is currently still running, but bounces when it is cold. I put my buddys tach on my tractor and it works fine, so the gear and cable are appear to be fine. Also, when it's really cold the tach loops over till it hits the stops.
Doc
01-02-2002 22:16:03
 Re: Tach repair. in reply to gibby, 01-02-2002 13:22:43
From what you are describing, I would lube the cable first. Unhook it from the tach, pull the cable out of the housing, put some light grease(there is a stuff called speedometer cable grease) in your hand and run the cable through the grease back into the housing, and hook it back up. If you have a tach bounce this is the first place to start, and the cheapest. Doc.
Glenn(WV)
01-02-2002 19:37:15
Any good speedometer shop should be able to fix it for you. HTH
Dann
01-02-2002 19:03:03
gibby: I was told Bates tractor parts in Burbon Ind, dose tach rework? dont know for sure , they have a 1-800 number Hope this helps Dann
Wayne
01-03-2002 15:56:15
 Re: Re: Tach repair. in reply to Dann, 01-02-2002 19:03:03
I gave Bates a box of parts and two weeks later got a new looking tach back that worked great for 100 bucks on my IH-340.
Wayne
