Farmall industrial A tractor
Tom Welch
01-02-2002 12:07:21
What are the differences between an industrial Farmall "A" and the normal Farmall "A" tractor?
Ken Williams
01-02-2002 15:35:45
 Re: farmall industrial A tractor in reply to Tom Welch, 01-02-2002 12:07:21
Tom; The industrial A has a foot throttle, in addition to the hand throttle. The front axle is also made of heavy, square tubing, and is adjustable. The serial number prefix for the industrial A is " IAA ", instead of " FAA ". I hope this helps you. (P.S. The foot throttle is located on the platform, with the clutch, and the brakes, on the right side of the brakes.)
tiny
01-02-2002 19:24:43
 Re: Re: farmall industrial A tractor in reply to Ken Williams, 01-02-2002 15:35:45
ken - did the industrail A have more horae power? rpm's?
Ken Williams
01-04-2002 15:26:42
 Re: Re: Re: farmall industrial A tractor in reply to tiny, 01-02-2002 19:24:43
Tiny; The horsepower and the rpm's were the same between the Farmalls, and the industrial "A". The other difference that I didn't mention in my other post, is that the industrials had the "International" name plate on the grill, instead of the "Farmall" name plate.
Glenn(WV)
01-02-2002 19:35:29
Nope. The square axle and the foot throttle were optional on the Farmall version. I've seen a Farmall 100 with both the foot throttle and the square front axle. It was originally purchased by a county maintenance crew for roadside mowing.
