706 3PT
Gibby
01-01-2002 14:11:14
Is there an after market 3 point adapter for a IH 706? If not, how hard is is to find a complete setup for one?
bryan ross
01-03-2002 10:26:04
 Re: 706 3PT in reply to Gibby, 01-01-2002 14:11:14
I found a place called Steel Wheel Ranch phone # 785-548-7437 which has a lot of items to help you out on the hitch. Good Luck
Gibby
01-03-2002 11:26:50
 Re: Re: 706 3PT in reply to bryan ross, 01-03-2002 10:26:04
Thanks Guy's
Dann
01-01-2002 20:28:59
Gibby: I bought a top link adapter through Steel Wheel Ranch that mounted easy on tractor and found an old fast hitch plow in a junk pile cut the the 2 point incerts off plow bought 2 weld on ball ends at tsc put togather and shoveld them in my 706 fast hitch now i can use all my 3 pt equipment got a bout $100.00 in it! hopes this might help you!
Don
01-01-2002 14:25:07
Yes there is an aftermarket three-point. I have one on mine. I bought it that way from a dealer in Pecatonica, Ill. I will have to go out to the shop & see if I can find a label on it.
